lifter tray?
Old 12-22-2008, 10:29 PM
wrenchhard01's Avatar
Talking lifter tray?
This will be my first LS build. Not that im new in this hp guest(been buildin sbc bbc chevys for years). Just have a couple of ? about these LS motors. Is there some mods for the plastic lifter tray. I mean do they hold up. It just seams like a weak spot to me. I plan on solid roller 8000rpm plus for about 25 30 min of hell. Because thats how I do that
Old 12-22-2008, 10:31 PM
firefighting1101's Avatar
you can use link bar lifters and do away with the trays
Old 12-22-2008, 10:32 PM
chase3's Avatar
checked into it for my build and didnt find much..i just put new ones in and thats all....damn i didnt know they even turned these motors that high on rpms
Old 12-23-2008, 01:03 AM
405HP_Z06's Avatar
Morel lifters with link bars; these eliminate the stock lifter trays.
https://ls1tech.com/forums/generatio...fter-pics.html
Old 12-23-2008, 12:31 PM
KCS
Moderator
KCS's Avatar
Crower and Jesel also make solid lifters for these LSx engines. Both have a link bar similar to the SBC and BBC lifters you may be familiar with. Jesel does make a solid lifter to use with the plastic trays though.
Old 12-23-2008, 01:30 PM
djwimbo's Avatar
We modded the lifter trays, since they're pretty much a bucket for catching oil, we increased the draining capacity of them. We were spinning 7200rpm often, I'm pretty sure that's where the limiter was. As for 8K rpm, let me know how you get there. I'm interested in a similar build.
and for what it's worth, I don't think you can use the stock ECU safely past 7800rpm. If you're going with a carb then you shouldn't have an issue.
