Trying for 45-50+ rwhp gain 5.3VsLS6 Heads+Intake and TB
Hey guys ive got a 2004 GTO with Mods and dyno numbers listed in sig and was looking to TRY and get 45 or so more rwhp. Im kinda on a budget and so far am stuck between the PRC Stg 2.5 5.3L heads and the Patriot Stg 2 LS6 heads for the money. kinda leaning toward milled 5.3's and crush head gasket to get close to 11:1 compression
I would also be adding a Throttle body (85mm minimum) and either porting my ls6 intake or going with a street warrior (if and when it comes out in feb). Sorry i can't afford AFR or Trick Flow but would love them! I was thinking i would try to get around 12 with an intake and throttle body and hoping for around 35 more from heads on top of that. What do you all think?
Id have to get a new TB wouldent I? ive got the stock 78mmTB now and it wouldent bolt to a fast would it? The pro products 85mm TB is under 200. Would it fit a Fast? 90mm+ TB's are expensive!
fwiw I have tsp stage 2.5 5.3 heads ported fast 90/90 with a TCI ssf 3500 stall and 3:23 gears it did 434 rwhp 407 rwt.Added 3:73 and gears and now it puts down 424 rwp..So it lose some dyno numbers but its deffinately faster..Oh yeah my cam is 232/238 6xx 6xx 111 lsa
I'm not a dyno numbers guy since I'm an A4 but hope this will give you an idea...I'm getting a new converter put in sometime next week.. its a circle D 5c converter and ita 42-4400 stall maybe be if jeff gets it in he'll take you for a ride..Its the blue formula..oh Go buckeyegoats.com!!
hey man my car will be at precision auto sport next week stop by and take a look at it or if jeff gets the converter in maybe he will take you for a ride..
Don't bother with the 85mm TB. it's a waste. just go 90.
https://ls1tech.com/forums/new-produ...ttle-body.html
Those look nice and aren't as expensive as many.
John, i have a 2000 M6 T/A i'm looking at doing a very similar combo too.. Would love to come in close those numbers. my cam is a TSP torquer V2 not quite as agressive and a 112 LSA 232/234, .595"/.598" My question to you is What exhaust do you have.
LS1Tech Premium Sponsor
The PRC 5.3l heads with thinner cometic gaskets & your easily at 50rwhp. These cylinder heads have proven themselves time & time again & are currently on special!!
We are offering free milling to get the compression up a little bit more with your camshaft, and we can ship the heads without springs for $200 less! That way you can install your spring kit off your stock heads if you'd like
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
what should the heads be milled t o if my cam specs are 233 236 .642 .597 112lsa
Out of the box with just clean-up milling to ensure they are flat they are right at 62cc chambers.
$934.99+shipping for the Stage 2.5 5.3L heads with no spring kit. Milling would depend on what lobes that cam utilizes and what kind of advance you run.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
