Alternator relocation?
Im in the middle of a LS1 swap out of a 2000 Firebird into a Honda S2000 and need to know if some make a alternator bracket to move it from the bottom of the engine to the top where the power steering pump was on a 2000 firebird's LS1? Can i use a C6 vette bracket to move it with they are mounted up top PLEASE HELP
I haven't seen any top mounted kits, they may exist, just don't know where. Wonder if you could modify one of the bottom mounted kits like these 2 and make it work up top? These 2 kits keep it on the drivers side but are mounted low and work with an electric water pump.
http://www.pcmforless.com/index.php?...d=98&Itemid=98
http://www.thunderracing.com/catalog...vid=3&pcid=307
You can use the corvette bracket. but it will only work with the corvette alternator. You have to shim it out to line up with the f-body crank pulley because the corvette accessories are further back. Street and Performance(http://www.hotrodlane.cc/) sells a bunch of acc drive setups if you want to check them out.
Looking at it after getting a little sleep last night it looks like my best bet is going to move it to where the A/C compressor was to avoid my electric OEM steering rack any suggsetions for moving it to that spot im not using the power steering from the LS1 nor am i using A/C since the car will have a rollcage and no top.
