Question about something I found under the hood...
Old 12-27-2008, 08:48 AM
camaro_five0's Avatar
Default Question about something I found under the hood...
I was just looking over my engine bay this morning and found some black soot buildup coming out from in between the passenger side head and valve cover. It's not a lot, I was able to clean it off with my finger. I guess I'm asking if I should be worried about this or not. My car runs fine, I havn't noticed anything out of the ordinary. The engine did overheat a little bit last month because my thermostat took a ****. The temp didn't max out my gauge, I was able to shut the car off in time. Other than that, nothing wrong.
Old 12-27-2008, 09:19 AM
wilwhite2kss's Avatar
Check on it in a day or so, and run a rag all along the valve cover where the head and gasket meet. If you have a fresh oil , pull the valve cover off , and check the condition of you valve cover gasket. I had this problem, and all i did was remove it , clean it , and reinstall it. Havent had a problem since. Dont worry , its not a major issue. Just replace the gasket if its bad. Hope this helps.
Old 12-27-2008, 11:13 AM
tnmotown's Avatar
your not having a header leak are you?
Old 12-27-2008, 11:27 AM
01ssreda4's Avatar
thats what i was thinking but wouldn't he be able to hear it leaking??
Old 12-27-2008, 11:41 AM
tnmotown's Avatar
yeah maybe, i had a slight header leak in the back of my headers once and could barely tell. But still had the black crap coming out of it a little.
Old 12-27-2008, 01:57 PM
No the headers are clean. The soot is coming directly from in between the head and the valve cover in the front. It's dry soot too, there isn't any oil with it.
Old 12-27-2008, 04:01 PM
01ssreda4's Avatar
might be oil and its getting hot/burnt so its dry.
