ticking after head install
Old Oct 29, 2005 | 07:29 PM
oange ss's Avatar
Default ticking after head install
I cant tell if it's the springs or maybe a header leak, it seems louder under the car than on top, oil pressure is about 43psi at hot idle, which is what it was before the install. I couldnt think of any way to prime the oil system prior to starting the engine, so i just started it up. There was some noise untill oil pressure built up, but i dont recall hearing that ticking noise until after i drove it around today to tune it. I reused the stock lifters, could one of them be bad ? thanx
Old Oct 29, 2005 | 07:40 PM
Brian Tooley Racing's Avatar
What cam and heads? What was the P to V clearance?
Old Oct 29, 2005 | 07:45 PM
black01_WS6's Avatar
ya need more info
Old Oct 29, 2005 | 08:14 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Possibly the wrong sized pushrods.
Old Oct 29, 2005 | 09:19 PM
oange ss's Avatar
TR224/.563 cam, PRC 2.5 heads, Thunder Racing 7.4 pushrods...didnt check the P-V clearance, I dont think thats what it is
Old Oct 29, 2005 | 09:26 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Your intake seated?
Old Oct 29, 2005 | 10:28 PM
oange ss's Avatar
yes......i dont know what a bad lifter in an aluminum block sounds like, hopefully it's just the double springs the heads came with, I'm gonna swap them out with the 918's i have and see if that helps
Old Oct 30, 2005 | 08:01 AM
RPO_Z06's Avatar
You should leave it alone, thats what it is, it just takes some getting use to.
Old Oct 30, 2005 | 11:18 AM
oange ss's Avatar
hopefully that's what it is, I cant deal with that tickin tho...i'll keep yall updated, thanx to everyone for the replies
Old Oct 30, 2005 | 09:15 PM
silverTA2002's Avatar
Does it sound like a sewing machine? If so, it's normal. That's from the heads.
When I had exhaust leaks, they would get louder in 4th gear when I put the car under load. That's how I could tell what the ticking was. I could feel the leak at idle when I put my hand right next to the exhaust pipe.
Some people suggest using a flower petal to check for exhaust leaks. See where it wilts.
Old Oct 30, 2005 | 09:42 PM
oange ss's Avatar
i guess the sound is more of a tapping than ticking, like i said it is more prominent under the car and in the car than standing above the motor. Even without a full tune it doesnt sputter or stumble or backfire, there doesnt seem to be any thing to point to a major issue. The noise seems to subside as soon as you touch the gas. I put a stethoscope on the valve covers and i can hear the springs but not the tapping. I'm beginning to believe it's lifter related. Any symptoms that you know of of a bad lifter ? Thanx for the reply
Old Oct 30, 2005 | 09:44 PM
oange ss's Avatar
and no it doesnt sound like a sewing machine.....
Old Oct 31, 2005 | 02:38 PM
10secopcar's Avatar
i believe i have the same thing going on. kind of a hollow tapping noise when first start it. then any gas and it goes away. and it has no set pattern of when it does it? i have comp r lifters in my motor. but after my trip to track something is not right. and the lifters are the only thing left we havent checked.
Old Oct 31, 2005 | 04:21 PM
oange ss's Avatar
well i changed the oil toady, because i put some cheap regular oil in it after the head swap to kinda flush out anything that may have gotten down in the motor while i had it apart, after driven around awhile the noise seems to come and go at will, with no rhyme or reason to it, so i'm gonna swap out the springs and see what happens.
copcar: if your car aint runnin right you may have a more serious problem than me, I have no personal expirience with Comp R lifters but i havent heard good things about them, i would probably start there if i were you
Old Oct 31, 2005 | 04:24 PM
oange ss's Avatar
and i'm almost positive i dont have an exhaust leak, atleast i didnt feel any
Old Oct 31, 2005 | 04:45 PM
Mr_president's Avatar
i just have a cam and my ticking is louud i think it is a liter as well dont get comp rs no offence i just hheard they fall apart allot you pay for what you get get the morals save 200 more$ that is what im going to do~
Old Oct 31, 2005 | 06:04 PM
jub jub's Avatar
I have the same noise and it comes and goes. It's probably valve train related but since so many people seem to have it, it must be normal. At 4000 rpm you don't hear it any more so perhaps the greater oil pressure keep the lifters pumped.
It's one of my many demons!
Old Oct 31, 2005 | 06:11 PM
TAQuickness's Avatar
seafoam makes an exhaust leak easy to spot.
if the valve train is ticking, something is not right. Would be best for you to spend some time measuring the valve train to make sure the geometry is correct.
oange ss's Avatar
i thought about the oil pressure thing too , but i have 41-43 at hot idle, oil pressure is not this motor's weak point
Old Oct 31, 2005 | 06:14 PM
oange ss's Avatar
i cant see geometry being the issue since i used GM head gaskets, heads and bolts, if it is off it aint by much...like i said we'll see what happens when i change the springs
