So my friend, [ A mechanic] ........
Old 01-03-2009, 01:05 AM
dannyz's Avatar
Default So my friend, [ A mechanic] ........
is willing to help me install my cam this next weekend.
The thing I worry about, is that I won't be able to get a tune till the first week of February.
The cam is a GM hotcam, going into my '01 Z-28 with an a4 tranny.
Will I be able to drive this thing around w/o it bucking and dying everytime I come to a stop?
What do you guy's think?
Old 01-03-2009, 01:10 AM
jsteele90's Avatar
i drove mine around for about a week being untuned. after about 2 hours it learned its idle and ran fine. just dont get on it and youll be fine
Old 01-03-2009, 01:50 AM
Psychopjv's Avatar
hot cam isn't very big you should be fine. Just do as stated above and not romp on her too hard. doing springs at all with it?
Old 01-03-2009, 01:58 AM
Mean87SS's Avatar
you should NEED a tune.... but it will gain from it.
Old 01-03-2009, 02:54 AM
dannyz's Avatar
I am glad to hear that.
Yeah, I have the LS-6 springs that cam with the cam that will go in with it.
I'm pretty pumped about this.
Just was concerned you know, about driving it around for a few weeks w/o tuning.
Thanks for the input.
Old 01-03-2009, 08:54 PM
98Camarod's Avatar
When I installed my cam I couldn't keep it running, good luck driving it around.
Old 01-03-2009, 10:07 PM
Psychopjv's Avatar
i put my 232/230 580/580 110 in without a tune. ran it for a few days.
http://video.google.com/videoplay?do...91333124&hl=en
Old 01-03-2009, 10:17 PM
01ssreda4's Avatar
tr224 cam here and it drove almost perfect except the factory idle being too low.
Old 01-03-2009, 10:20 PM
Slvr00Bird's Avatar
Yours is a 230/230 grind though..
The hotcam is very mild..
98Camarod's Avatar
I know I'm not the only one. yank ss4000, comp xer 230/230 .591/.591, ls6 intake, headers. It started, idled high and I got it up to temperature and that was it.
Old 01-03-2009, 10:39 PM
Shawn MacAnanny's Avatar
You should be ok but I would wait to do the swap until you have everything ready. It might try to push through your bakes without a stall although as mentioned its not a very big cam. Be sure to buy red thread locker for you cam retainer and camshaft bolts.
Old 01-03-2009, 11:25 PM
beezer1519's Avatar
and try not to push the car too much as it will most likely be running a little lean
Old 01-04-2009, 10:41 AM
Sube's Avatar
I ran my car with an ms3 and PRC heads for about 3-4 months tuned with just diablo handheld, which honestly isn't anywhere close to a real tune. I prob put around 1500-2000 miles on it. It prob helped that my car is an m6 but i found my car livable and actually romped on it a few times, but you prob won't find anyone telling you to do that lol.
Old 01-04-2009, 10:48 AM
moeZ28's Avatar
I had the hotcam for about a month before I got it tuned in my old 98 z28 auto with a stock stall. It will sound absolutely nasty (awesome) and it will buck a little and surge some, maybe even die occasionally, but not very much and not all the time. Its not that bad, but it is a little rougher than some people on here are telling you. With your looser converter, it should be alot easier on you though. But you will definitely need a tune!
