What is an LS1 with a spun rod bearing worth?
Mods, if this is the wrong forum please move the thread. This build has less than 10,000 miles on it, not built by me. The motor spun a rod bearing at about 10K of daily driver use. The block had about 117K when it was built. It's a '98 LS1 (yes aluminum block) honed 347 with 10.1 forged weiseco pistons, forged rods, polished gm crank, ported LS1 heads, hardened push rods, new springs and rockers, custom comp spec'd turbo cam (560ish lift), and new LS7 lifters. What would it be worth as is? Just trying to get a ball park figure to see if it is worth my while to repair and sell or sell as is. Thanks
About $10 shipped to my door. lol j/k. I would pull the pan and inspect the crank and rods. Maybe you can just get the crank turned and replace the main and rod bearings. It shouldn't cost that much to get it turned and you can sell it for alot more.
If anyone else has an estimate for what this LS1 is worth, please post.
South FL I would rather get rid of it and start with a new iron short block or a low mileage 2001+LQ4, I'm already turbo and don't really care about the extra 100lbs it will add. If I can't get rid of it for a decent amount, I'll try to repair later down the line after I have a new motor in the car.
As is I wouldn't pay more than ~$300 to 400 max...because who knows what you'll find on tear down on an unknown engine...it might be just a bearing or it might be the whole motor is trashed. However, with all the stuff you've put into it, I'd tear it down and see about fixing it, if it was my engine instead of trying to sell it as is.
in its current state no more then a stock ls1 with a spun bearing. as said before you dont know what you are getting when u buy a damaged motor. so all the good parts you have in it would be a lose for you or a bonus for the buyer depending on if they are all reusable. i say 300-400.
Thanks for all of your input. Yea, you guys have me convinced to try and fix it before even trying to sell it. The motor just has a slight tick, perfect oil pressure and drives fine just does not put down the power. I only drove it 5 miles to get home after it happened and the car was driving fine under partial throttle. The car has not been driven since, only turned on for the engine builder to inspect. I'm going to save for a new built short block and when I have it in my car and running again, I will work on the LS1 at my own pace. Just sucks to see a turbo V8 sitting there knowing I can't open it up. Going into boost has become an addiction...
well i kept my crank and got about 20 bucks scrap out of the bare block pistons and rods...mine didnt spin the bearing...oil starvation got it and put the rod bearings in brass and a couple of them into the crank...in the process it effed up 3 of the cylinders so my block was junk....
It was tuned to 6.5K limit on what I believe is a baby turbo cam 222/224 comp with about .56X-ish lift. The more I hear about this happening to people, the more I just want to buy a new forged short block. I'm just going to save for it, a new 370 built forged iron block seems like the least expensive route, for a decent platform. When I get a motor in the car, I'm going to tear down this LS1 on my own (first LS1 tear down) and see if I can salvage it and maybe turn it into a side project. Worst case scenario, it gets scrapped.
i found a low mileage 5.3 03 model after sellin the harness ive got 250 bucks in an iron block that im gonna have bored to the 346 and put forged internals in....but a forged 370 sounds awseome...good luck...
[QUOTE=omore001;10793673] The motor just has a slight tick, perfect oil pressure and drives fine just does not put down the power.= QUOTE]
Are you sure it is a spun bearing? That usually makes the oil pressure drop.
I know a spun bearing usually means low oil pressure or even none at all, but when it happened, I just caught it and did not ride for more than a minute after it began. It's possibly not yet reached a level of catastrophic failure, ie: great oil pressure, I cranked it 2 days ago and cold start pressure came up to almost 60psi instantly.The block has not been stripped bare yet, so I can't justify that it is just a bearing, but this is what I have been told by an LS1 engine builder/tuner who knows his stuff and has been doing this for some time, when we had the motor torn down to the lifters. The car really does drive fine, but wont rev as hard or as fast as or as high as it used to, wont hold any boost either, the boost reads 0 lbs WOT.
