Milling 5.3L heads
Old 10-07-2003, 08:51 AM
BadAndy's Avatar
Default Milling 5.3L heads
If I milled a set of stock 5.3 heads to give an 11:1 compression, and changed nothing else, would that be enough to get 10 or 15 hp out of?
Old 10-08-2003, 11:13 AM
BadAndy's Avatar
Default Re: Milling 5.3L heads
ttt
Old 10-08-2003, 11:54 AM
Fireball's Avatar
if these are for a LS1. Then you'll probably not gain any power...more like lose power due to the smaller valves found in unmodified 5.3L heads.
Old 10-08-2003, 03:57 PM
BadAndy's Avatar
what if I milled stock LS1 5.7 heads to 11:1?
Old 10-09-2003, 11:41 AM
Fireball's Avatar
if you mill a stock head you can increase combustion efficiency...but I doubt it'd be more than a few HP. If you mill enough to reach 11:1 you then have to start worrying about PV clearance if you run an aftermarket cam.
Old 10-09-2003, 10:38 PM
Jabroni's Avatar
I'd say that a bump in compression that slight will get you maybe 5-8 at the wheels. Don't expect much out of it. Milling too much will seriously limit the amount of cam you can choose from without getting one ground special.
Old 10-10-2003, 05:59 PM
BadAndy's Avatar
sheet
