GM Long Block Gasket Set for rebuilding P/N????
Old 10-09-2003, 08:09 AM
Moderator
John B's Avatar
Default GM Long Block Gasket Set for rebuilding P/N????
Is there is a gasket set which includes heads bolts for rebuilding an LS6 long block that includes head bolts? Am I just better off buying the individual gaskets for the oil pan, timing cover, etc? I have a new short block & heads that I am building up so I don't have any gaskets right now, thanks!
Old 10-09-2003, 10:14 AM
onyxxtreme's Avatar
Default Re: GM Long Block Gasket Set for rebuilding P/N????
SDPC sells "Cam and Head Swap Gasket Kits"
included are all the gaskets need, plus GM head bolts, balancer bolt
I dont know if its on their website, cause i read this out of their catalog
Old 10-09-2003, 12:32 PM
Camaro_Zach's Avatar
sdpc is a sponsor of this site...
http://www.sdpc2000.com/cart.asp?act...&catid=873
Old 10-09-2003, 01:51 PM
I can shift faster than you.
Jason99T/A's Avatar
John, give Paul @ Thunder Racing a call. We have a longblock gasket kit that is not yet up on the webpage. It includes every gasket you need to rebuild your LS1 from the ground up.
www.thunderracing.com
877-516-7223
