57cc, 58cc, or 59cc prc 215 heads?
im trying to get as close as i can to 500whp n/a and possibility of spraying a 100-150 (to the wheels) im at 425 mustang dyno and i am wondering if i will have any problems with a wet kit or valves hitting with 57cc or 58cc
stock bottom end**
stock bottom end**
1 Post
What kind of pistons? stock, flycutt, or dished ??
Duh I just noticed stock bottom end
I think you will be pushing it about as close as you can get without actually touching unless you flycutt the pistons. JMO Hopefully someone else can give you a more definative answer.
Good luck !!
Good luck !!
