Help new heads and cam and car wont respond
I just finished putting this stg 2 settup from ARE and the car wont respond when I step on gas.It just revs a little and stops.I also installed 42pound injectors and the 255 walbro fuel pump.I'm crrently running 91 octane.Please guys any suggestions are fine.Thanks
Re: Help new heads and cam and car wont respond
I wouldnt drive around too much with the 42#'s in the car. You will kill the plugs and possibly hurt the rings.
Change the plugs before you dyno, they will definitely be toast.
Cheers,
Chris
Cheers,
Chris
Dont drive the car till you get in it to drive to the dyno.
Ideally throw in the new plugs when you arrive at the dyno and throw a base tune for the 42#'ers in the car. Then do your pulls and see how everything looks. Doesn't take long to kill a set of plugs with those big injectors
Cheers,
Chris
Cheers,
Chris
