MS4 Cam
There is NO NEED TO FLYCUT this cam on factory heads. As far as aftermarket heads, it just depends which one you are looking at. If it is a ported GM casting that has aggressive milling or larger diameter valves, you will need to flycut. However, several of the aftermarket casting heads including the PRC castings, AFR 205, and TFS heads should clear without issue.
As for the performance of the cam, it was designed as an all out cam for stock cubes. It will pick up in the neighborhood of 80+ FWHP with the correct supporting mods. It can be daily driven but if bottom-end power or like stock driveability is what you are looking for, I wouldn't recommend this cam. We can get you setup with the right cam for those goals as well. On the other hand, if you are looking for everything you can get HP wise out of your engine, there is no need to look any further!
Let me know if you have any question and we'll get you fixed up asap!
Jon
Jon
Make sure you guys understand that this is a big stall and big gear cam. You auto guys are going to want to use 4000-4400 stall but some have gotten away with 36-3800 stalls. Gear wise 3.73-4.10 is what you should be looking at. I would not reccomend putting this in your 3000 stall 3.23 rear gear car because you are not using the full potential of the cam.
