can the head surface be to smooth?
Old 02-27-2009, 09:44 AM
quick346's Avatar
Default can the head surface be to smooth?
I want to cut my afr's a little more and our bridgeports at work are old as hell
and if i want to use the cnc's my boss will prob charge me machine time around $90 a hr so that is out
so i want to set them up in the wet grinder and just grind off the .015 i want to take off them
but will that be too smooth for the gasket to seal? i run cometics and i think the smoother the better with them just wondering what the thoughts are on this
thanks
mike
Old 02-27-2009, 09:54 AM
sroach20's Avatar
there is no such thing as too smooth. its the imperfections like scratches or gouges that create the leaks.
Old 02-27-2009, 10:18 AM
XtraCajunSS's Avatar
You want to run between 20-30 RA (Cometic requires a finish better than 50 RA)
Shane
Old 02-27-2009, 11:17 AM
vettenuts's Avatar
Talk to Cometic directly. Flatness is as important, I think it is 0.001 runout over the width and slightly more over the length. My AR's had 0.0005 over the length.
Old 02-27-2009, 12:06 PM
quick346's Avatar
ok thanks guy's. a guy at work told me that if it was too smooth the gasket would not hold onto the head and push out.
kind of made sense but really i can't see that happening i think the main cause of failure would be from imperfections on the surface causing a leak .
off to the grinder they go
Old 02-27-2009, 04:49 PM
DaddySS's Avatar
I believe cometic specifies not to cut them too fine, check their website.
Old 02-27-2009, 06:22 PM
TJ
TJ's Avatar
its going to have to be done correctly for the cometics to seal up.
good advice from shane above.
i worked my setup around a stock head gasket, because i didnt want any issues.
