Cam "experts", what would you......
Old 10-17-2003, 10:13 AM
01Z0H6's Avatar
Default Cam "experts", what would you......
suggest for my daily driven A4,
All bolt on's, headers,ory,borla,fipk,tci 3200,342 gears,custom tune.
Nothing too radical, just something to "give it a kick" & still run efficiently.
TIA, Matt........
Old 10-17-2003, 10:26 AM
CHRISPY's Avatar
Default Re: Cam
Probably a TR 224/224 on 114 or similar
Old 10-17-2003, 07:04 PM
01Z0H6's Avatar
Default Re: Cam
Out of 42 people 1 response!!??
Thanks Chris 4 your time. i will research.
Which brand?? If you please???
Old 10-17-2003, 07:14 PM
SPANKY LS1's Avatar
Default Re: Cam
IMO, there are two kinds of cams, all out (G5X2, TR 236/230, MMT M2, MTI X1, basically anything 230* and larger duration). Then there are the "sleeper" cams. (Thunder Racing 215/220 115, MTI 224/220 116). IMO, if you are going to add a cam, either make it radical so you get maximum HP, or make it a sleeper, so that it drives and idles like stock.
I would personally run one of the "sleeper" cams listed above, you could get to 360+ with some boltons (A4), and sound/idle like stock. IMO, if you go with a 224* or larger cam, your car will sound like it has a cam, and if its gonna sound like you have a cam, might as well have a cam .
Good luck, Shawn
Old 10-17-2003, 08:36 PM
01Z0H6's Avatar
Default Re: Cam
Thanks Shawn. Guess that's what i need. someone to tell me where the "rubber hit's the road" so to speak.
360+ sounds great to me! More like 385 so i can keep up with the 01 Z06's
thanks again for the advice.
Old 10-17-2003, 09:56 PM
99 Black Bird T/A's Avatar
Received 1,432 Likes on 992 Posts
Default Re: Cam
Maybe a 224/224 XE-R on a 114-115 LSA with a very quiet dual/dual would be the ticket.
My 224 XE-R on a 113 LSA is quieter at idle (when warm) than my wifes Z28 with a loud cat-back is.
Otherwise, TR224 on 114 LSA
Old 10-18-2003, 11:07 AM
do0dfromcali's Avatar
Default Re: Cam
What about the MTI B1 cam?
Old 10-18-2003, 12:31 PM
SNAXS's Avatar
Default Re: Cam
or the MTI Stealth Cam?
Old 10-18-2003, 02:17 PM
Z06Les's Avatar
Default Re: Cam
I agree - on a .565 lift or so. Comp Cam's can set you up fine.
Les
Old 10-18-2003, 02:20 PM
01Z0H6's Avatar
Default Re: Cam
Thanks men!!
Old 10-18-2003, 04:47 PM
lsx24's Avatar
Default Re: Cam
IMO, there are two kinds of cams, all out......Then there are the "sleeper" cams.
That's true, but I would add one more category: biggest cam that will pass emissions. This cam will be bigger than sleeper cams, and will lope slightly, but be less aggressive that "all-out" cams.
An example is the TR224/114lsa. This cam has repeatedly passed California sniffer tests, but by no means is a sleeper cam.
Old 10-18-2003, 05:11 PM
01Z0H6's Avatar
Default Re: Cam
I have had my car tuned....... With the above cams metioned, will i need to "retune"!
Let's just say i get the 224/114......? thanks.....
