2001 need rockers in cam swap??
Hi I'm getting all my parts together for May when my warranty runs out for my cam swap...
So far:
Jet hot long tubes
TSP lid
230\228 112LS cam
Combination motorsports springs and titanium retainers
Getting:
ASP pulley, 30# SVO's, timing chain (any suggestions), maybe a New oil pump.
One EXPENSIVE peice I'm worried about is the rockers I know some have had problems with the stock ones falling apart and needles getting into the engine. Is this a problem on ALL LS1's or just the early ones? Is it a good idea to get a set of aftermarket rockers for the cam swap?? The damn things are expensive I could buy a nitrous kit for the same price!!!
Thanks!
Bobby
So far:
Jet hot long tubes
TSP lid
230\228 112LS cam
Getting:
Thanks!
Bobby
Re: 2001 need rockers in cam swap??
Only reason I was going with the injectors is because the shop Force fed performance tuning suggested I get those????? I would be going with a wet kit after I get a rear end so injectors shouldn't matter there...
I'll pass on the rockers then for now and maybe get them on there next spring change!
Thanks for the response!
