old racer
old racer
I have a new L92 an need to learn what new additional required pieces I need to change out the cam to a non vvt unit and also provide a cam sensor on the timing cover for the programer that I will be using. ie: will the lifters work, is there some sort of a block off plate behind the cam, what timing cover will accept a sensor, etc ? Thanks in advance. JC
