torque sequence for valley pan??
I dont think its critical, like a cylinder head is. Ive changed the bolts many times when swapping a FAST LSX intake.
I get them all in and down to the point where they start to torque. Then kind of start in the middle and go out.
But Im sure there is a "true" sequence and torque spec. I dont have it, but Ive never had any problem with the method I use.
Important: All gasket surfaces should be free of oil or other foreign material during assembly.
1. Install NEW knock sensor oil seals (1) into the valley cover (2). Lubricate the seal surfaces with clean engine oil.
2. Install the valley cover and NEW gasket. Notice: Refer to Fastener Notice in Service Precautions.
3. Install the valley cover bolts. Tighten the valley cover bolts to 25 Nm (18 ft. lbs.).
4. Install the knock sensors. Tighten the knock sensors to 20 Nm (15 ft. lbs.).
5. Install the knock sensor wire harness.
Thanks... hopefully this OLD valley pan gasket is still good
(Oh, btw nice punk using the pic sweetS10V8) :o
