LQ9 or LQ4
Location: Currently, Zormat, Afghanistan....Home staion, FT. Richardson, Alaska
LQ9 or LQ4
What is the difference between the two? Which Is better? I tried the search but no dice.
so both blocks rods cranks are the same? minus the 99-00 lq4 cranks which wont bolt to the t56 and 4l60?
I do...
basically the differences have been mentioned already...
the LQ4 pistons are dished for lower compression... ideal for boosted applications
the LQ9 are flat topped... better for NA cars
both are iron blocks
in my case i have an LQ4, but I milled my heads to raise my compression back up.
I do...
did u like ur 6.0 better than ur ls1 motor?
I do...
what H/C/I combo you using? hp/tq? You like it better?
