Who has replaced the knock sensors?
It doesn't take long. I think maybe a couple of hrs maybe for the first time. I think it's a 7/8" socket to take the sensors out. Just be careful pulling the intake off so you don't break the oil sending unit and be careful disconnecting the connectors to the knock sensors cause they are delicate unless you plan on replacing the harness for them. Also, after you put in the new sensors the rubber plugs that cover them, put some silicone around the edges to keep any water/condensation out of them or you'll be replacing them again.
What he said ^^^ not to bad. Also if you can afford it upgrade to a ls6 intake manifold while its off.
http://www.ls1howto.com/index.php?article=5
