346 to 347
Old 04-05-2009, 07:52 PM
blackhawk0251's Avatar
Default 346 to 347
Well..my motor is fucked up, a rod is broken...I know someone who has an LS6 block with 20k on it they will sell me. I can get a 347 rotating assembly from texas-speed....Will all of the parts fit into a 346ci LS6 block?
Old 04-05-2009, 07:54 PM
randomnine7's Avatar
yes ! it will need to be bored over just a lil bit ..
Old 04-05-2009, 07:59 PM
Can they bore the steel sleeve or would it have to be resleeved?
Old 04-05-2009, 08:29 PM
conan's Avatar
You hone a few thousands out of the cylinders.
Old 04-05-2009, 08:35 PM
now what about a 402 rotating assembly? Would I be able to fit a 402 rotating assembly into the LS6 block? How much would I need to bore the engine over? Would I need to re-sleeve it?
Old 04-05-2009, 08:39 PM
conan's Avatar
You could get a 383 stroker rotating assembly. You need a 6.0l with a stroker kit to go to 402ci. Resleaving a ls1 is not worth the money.
Old 04-05-2009, 08:50 PM
Ill take your word for it lol..I think what im going to do is build this LS6 block that someone has...and possibly put the LS6 heads on as well, and cam it..
My Plans:
Texas-Speed 347 Eagle Rotating Assembly
LS6 Block w/ LS6 heads
Cam (probably custom grind)
Hope for 380 rwhp through an auto
Things I already have: I havent put these on yet
Performabuilt Stage 2 4L60-E
Yank PT 4400
Pacesetter LT's and Y pipe (from texas-speed )
Old 04-05-2009, 08:57 PM
conan's Avatar
You should reach your goals with a good cam.
Old 04-05-2009, 09:18 PM
just buy a iron block 408 from tsp .. 3800 shipped .., best bang for the buck and alooot of potential ! especially for nitrous boost ..
Quick Reply: 346 to 347
