Heads/Cam= maxed out injectors???
I would say I havnet seen any 450 hp cars with anything less than a 30# injector. Plus when saying 450 hp is the max would that be for M6 ? What about an auto that looses alot of power through converter . I personally think mine are Maxed out at 420hp in my auto. I might be off but Ive never seen 420+ rwhp autos with stock injectors either. Like I said I could be way wrong but from what ive seen around I think you can defintly max out the injectors.
Jeremy
Jeremy
If you are going by the rule of thumb that you want your injectors to be around 80% duity cycle then yes, a H/C package can definately max out your injectors.
Check out this thread for cycle duity & HP ratings:
https://ls1tech.com/forums/pcm-diagnostics-tuning/108165-2002-z06-injectors.html
I believe it's possible to make those high rwhp claims with stock injectors using an adjustable fuel pressure regulator. Of course raising the fuel pressure puts a higher load on the fuel pump and can cause earily pump failure. It can also cause tuning issues at low engine speeds.
Richard
Richard
