parts for changing lifters, etc
so after my cam install i have a pretty healthy lifter tick problem and changing to heavier oil only made it take longer to tick...so my only rationality is to just tear into it and replace the lifters but im curious what parts i will all need to get it done other then the obvious (lifters)...so what bolts, gaskets, etc will i need?
i want to put the smallest headgasket possible on it as well to bump up compression a bit, what would you recommend?
any help is appreciated, thanks!
