combo for M6 2001 camaro SS , need your opinions
Hey guys , my buddy have 2001 M6 SS , i'm planning and working to make an Awesome project with all high quality parts , the parts i purchased for him below :-
-Kooks headers 3/4
-Kooks y-pipe
-BORLA ADJUSTABLE CATBACK
-spec clutch stage +3
-spec aluminum flywheel
-SLP DOUBLE TIMING ROLLER CHAIN
-AEM WIDEBAND GAUGE Air Fuel
-COMP 7.400 pushrods
-high flow Air filter
-SLP pulley
-prothane kit
-LS7 lifters
-SLP lid
those parts cost me $3886 ,the next step heads/cam/pistons/rods and ARP bolts/studs , now i'm looking for the heads and cam , of course i'll chose Trick flow , but what chambers should i buy ? and what cam i should buy ? i wanna spray 200HP.
need your opinions any opinions will be welcomed
thanks, Mohammed.
-Kooks headers 3/4
-Kooks y-pipe
-SLP pulley
-prothane kit
-LS7 lifters
-SLP lid
thanks, Mohammed.
I would say the 59/60 cc chambers would be what you want to get the compression where you need/want it...a little over 11:1 with an .040 gasket.
You may need to fly cut the pistons if going with a cam that wild and having milled heads. Contact the camshaft supplier and see what they say about that.
I think you need to add a rear end to that list. You at least will need lower gears with a big cam but adding the heads and spray is gonna go beyond what the 10-bolt can think of handling.
the last thing i'll upgrade the rear end , maybe we'll install 3.5 or 3.7 gears
