crank sprocket
crank sprocket
I'm in the middle of a cam install and bought an adjustable timing set. this set has the adjustable cam gear with the bushings, so i'm wondering if i need to change the crank sprocket? and if i do, is there an easy way to get it off?? Thanks
You can buy the correct tool for about $14 off of fleabay but of course it will take a few days to get. Some have used a small three jaw puller. You should change it so that all parts are new/matched and wear in together. The crank side is the chain wrap side so that is more important.
