Head/Cam help
Head/Cam help
So I'm looking to build a N/A higher compression LS1.
Could I get some links or some insight on where a good starting point would be as far as heads and cam go. I have no problem with doing my homework I could just use a little help on where to start. Any recomendations as far as heads and cam go for a higher compression N/A build? This is my DD so I'm looking for something streetable.
Thanks
Thanks
If you want more info you can talk to someone from texas speed, but as far as ive heard the milled 5.3 heads with the ms3 cam is the way to go if you want higher compression and still be a dd.
How much money do we get of yours to spend?
If your not on a much of a budget than AFR's or TrickFlows would be good.
If your on a budget, than milled/ported LS6's or ported 5.3's would be good.
Those with a matching camshaft,intake manifold, and stall converter if its an auto.
