"Max lift" on stock heads?
I've done some searching and havn't really found anything, but I've got stock heads and a TR224 cam, duration is 224/244, 112LSA, and lift is .563/.563. I'm looking to get a set of 1.85 ratio roller rockers which will put my total lift at .613 at both valves. will this have clearance issues with stock heads and pistons or should I be alright?
The heads wont have a problem with .613" lift, thats everyday lift now. As long asa you dont have some wicked spring combination.
You have to check pitson to valve clearance no matter what ANYONE tells you. Because when your pistons and valves crash, its your own fault and you have to pay the bills to fix it.
yeah, i know theres no substitute for a clearance test, I was just checking to see if I'd get a "no thats too much" response to just scrap the idea, which it doesnt seem like i'm getting
anyway though, with thunder racing's warning against 1.8 ratio rockers I'm not gonna go with them.
thanks for the info guys
