LS6 Heads or 5.3 Heads?
What do you guys think are a better set of heads? I will take them to be machined and everything im just not to sure what ones to go with cuz i hear good about both. i plan on puttin in the street sweeper high torque camshaft if that helps any. all of my other mods are in sig. thanks alot guys.
it is always better to go with a custom grind.. as long as your talking to a knowledgeable person.
thing is.. i like the ls6 heads better.. your going with a cam that has high tq... therefore if it were me i would focus everything on tq... that cam im going to assume loves mid range.. therefore right after the 60 foot mark is where its going to come alive, then die off near the end of the track..
if that cam has to be the one.. i would go ls6s 5.3s 3500 stall (but i think your an m6 so X that) 410s etc etc etc.. take a little weight out..
if your going off the shelf... and you want to go with ls6 heads (my personal choice for heads on a budget).. i would go with a bit larger cam.. something like an ms3, torqer, etc... they like to breath a bit more.. which means you would want to upgrade to a minimum of a 90/90, but they are getting very cheap nowadays used..
just depends on what your wanting.
