Install Problems; Need Help Quick!
Old 11-09-2003, 12:01 AM
Richie Rich's Avatar
Question Install Problems; Need Help Quick!
I am trying to do a cam swap and ran into a problem that I need some help with. I need to know if anyone can help steer me in the right direction on how to remove a ASP underdrive pulley? I went to InstallUniversity.com and their instructions say that there 'should' be a lip inside of the pulley about half way back that you can hook on to. Well mine does not. Can anyone please help me? Would like to at least still get the cam in tonight so I can finish up the heads tomorrow.
Old 11-09-2003, 12:12 AM
HumpinSS's Avatar
Does it have three holes in the center hub. If so you need a different type of puller that can be rented from your local autozone. I am not sure but i dont think you are supposed to pull pulleys back off from the outer hub. I recently did that on my SLP paper weight(caused KR) and it ripped the pulley apart.
Old 11-09-2003, 12:18 AM
There are three holes on the outside portion of the hub. Which puller do I need from auto zone?
Old 11-09-2003, 12:20 AM
HumpinSS's Avatar
If you look at all the tools they rent out you will see in their specialized puller section a puller with three rods on it. This should be the one
Old 11-09-2003, 12:26 AM
jrp
SN95 Director
jrp's Avatar
the 3 screw pulley puller should look something like this.
Thank you so much!!!
Old 11-09-2003, 12:35 AM
2xLS1's Avatar
You need a puller like this.
http://www.toolsource.com/ost1/produ...1ErrString%3D3
The threads in the pulley are not metric. You will need (3) 5/16 - 24 thread bolts about 1 1/2 inch long to use with the puller.
Old 11-09-2003, 01:03 PM
BriGuy's Avatar
Okay so I am helping Richie Rich with the install. We need to know for sure which one we need to use. Thank you.
Old 11-09-2003, 01:18 PM
2xLS1's Avatar
Go to Autozone and get this one. http://www3.autozone.com/servlet/UiB...c_balancer.jsp It's similar to the first one I posted and will work. You will get your money back when you return it. Just make sure the bolts you use to screw into the pulley are 5/16 - 24 thread or you will F/U the pulley.
Old 11-09-2003, 07:59 PM
Originally Posted by 2xLS1
That was the right pulley puller, but Autozones was to small. Fortunately, my buddy had the right sized one. Thanks for all the help.
