oil pressure issue/ hoping its the sender
Old 06-15-2009, 07:01 PM
scites's Avatar
Default oil pressure issue/ hoping its the sender
ok just got my new 402 in the car and got it fired up and at a cold idle is is at 40 psi which is a little low and then when it warms up at idle is is at 20psi and while driving it goes up to 30/40 depending on RPM. i grabbed the oil sending unit and i can move the plastic part, it will turn back and forth a little..you guys think the sendning unit is the problem..i sure in the hell hope so..im going to buy one tomorrow and swop them out..let me know what you think
Old 06-15-2009, 09:27 PM
SOMbitch's Avatar
If it loose it is possible but they usually leak if it is cracked /loose so GOOD LUCK.....
Old 06-15-2009, 10:26 PM
bigboykilroy's Avatar
A good place to start, but a pressure leak would result normally in a fluid leak as well.
Old 06-16-2009, 12:36 PM
srpoweredcoupeNWH's Avatar
It could possibly be the o-ring on the pickup tube is pinched. A buddy of mine did that on his vette and it did the same thing.
Old 06-16-2009, 07:20 PM
scites's Avatar
well i changed the sending unit in the parking lot at work last night..took about 20min and i have a nice burn mark on my wrist..motor was hot..lol..didnt really help might be 2 to 3 psi higher..guess im going to pull the front of the motor back down and change oil pump and pickup tube packing
Old 06-16-2009, 07:24 PM
STAR's Avatar
What oil pump do you have in there now? Is it a ported LS6?
Old 06-16-2009, 09:35 PM
SOMbitch's Avatar
How did you do it twenty minutes??? You had to pull/reinstall IM right???? more than a 20 minute job for me.....
Old 06-16-2009, 11:27 PM
scites's Avatar
hell no dude..reach behind the intake. go around on the drivers side and stick your right hand back around the back of the intake..arms get a little scaped up, but you can do it..i have a typhoone intake that stays hot and i did it..have a nice burn on my forearm to prove it..lol..iv changed 2 of them now that way..i dont kow if the typhoon makes a difference or not..
Old 06-17-2009, 10:37 AM
SOMbitch's Avatar
I have tried and couldn't get to it and had to pull my FAST I wouldn't think it would make any difference which IM
I agree with srpoweredcoupeNWH and would check the o ring next.
Let us know how it turns out........
Old 06-17-2009, 04:56 PM
scites's Avatar
going to pull it down this weekend and change the packing
