how hard is it to swap heads
Old 06-16-2009, 06:29 PM
97ta383's Avatar
Default how hard is it to swap heads
Im geting a set of prc stage 2.5 5.3 heads soon with my stock cam and ive heard swaping heads isnt to hard just takes time and ive been under the hood many time just not to much with internal engine and the only thing im nervious about is torqueing the heads i saw how they do it on ls1howto but is that the right way has anyone else done it differently? Thanks
Old 06-16-2009, 06:49 PM
ss.slp.ls1's Avatar
Yeah that's the way you should torque them. How else would it be done differently? There's the other way and the right way...
Follow that guide, take your time, and you should be good to go. Why not install a cam at the same time?
Old 06-16-2009, 09:45 PM
SOMbitch's Avatar
The guys who say it easy always amuse me. Very doable but not a fun job by any means. Just curious... are you gonna you use studs, ARP's or GM TTY bolts?
Old 06-16-2009, 10:40 PM
Cruzer23's Avatar
I heard heads are easy, but cam is more difficult. Is that true?
Old 06-16-2009, 10:52 PM
racerx82989's Avatar
I'd say that its true. Heads for the most part just bolt on. A cam install is quit a bit more complex (alot of things to make sure that are lined up and installed correctly)
Old 06-16-2009, 10:56 PM
01FbTaWs6's Avatar
heads are not hard at all if you take your time! The hardest part of doing a head swap is getting the 2 ground bolts undone on the back side of the drivers side head. Other then that, its pretty easy sailing.
Old 06-16-2009, 11:04 PM
DustinWS6's Avatar
It's not too hard, you just have to take you time and be patient. Don't break the oil sending unit that is located behind the intake. I took my time and managed not to break it.
Old 06-16-2009, 11:38 PM
bigboykilroy's Avatar
The biggest thing is to make sure you get ALL the coolant out of the head bolt holes !!! if you dont you will crack your block when you put the new bolts in. I like to take out the block coolant plugs, one on either side of the block. gets alot of the coolant out of the top of the block.
