White smoke from driverside header only?
How do you know thats its only coming from the driver side? Are you running open headers or something? Either way white smoke is a good sign of burning coolant, and you usually don't blow both gaskets at the same time. But I would replace them both if thats you problem.
yes, I am running open headers. if I had a blown hg would there be whitesmoke immediately from a cold engine or only once it is warmed up? there doesn't seem to be smoke until it is warm. I did wrap the headers and believe there is brake fluid on the driverside so it could be that...... ;(
Good news. Header wrap was doused in brake fluid. Took the wrap off and no more white smoke Gonna be a bitch though to wrap it again while on the car Thanks to everyone for the advice.
