Valvetrain noise--loud!
Just got my forged 348 fired up for the first time last night. Couldn't run it for more than 90 secs at a time beacause I didn't want to damage anything. I am getting a really loud clacking noise from the valvetrain. Oil pressure is good. I set the comp 1.75s at. 1 3/4 turns. Is this too loose? Does it take a few min for new lifters to pump up?
Here's what I got:
Ms3, new ls7 litters, hardened pr's, cc 1.75 adj, dual valve springs
TIA
Here's what I got:
TIA
Does no one pre soak their lifters anymore? Have you checked for an exhaust leak at the header flange they can sound like all kinds of things from valvetrain to a rod knock. That is where I would start
i soaked my lifters for 3 days lol, every set of the re assembly i would add oil. poured oil on my installed lifters in the pushrods after fully dipping both ends then in the top of my heads and on my roller rockers. I figure i have to put 5.5 quarts in the motor regardless.
I actually followed some posts in here regarding Vinci's/cranes instructions for lsx lash-2 full turns.
Guys at TSP advisede the LS7 litters reguire more preload-(.100-.120)
This preload set my roller tip a bit behind centerline w/ 7.250 pr's (shaved 5.3's)
I actually did soak my lifters but it been about a week between install and fire up. I did add the oil over the rocker down the pr's etc.
Sounds Better
Thanks for all the help.
WYATT318MOPAR: Yeah, I used copper Gaskets and turns out I needed to re-torque them a couple more times.
Just got the car tuned and its running a lot better, still have some valvetrain noise, but from, reading the boards this may be normal.
I've got some bucking down low in the rpm's (under 2k) but the tuner says he can fix that now that I replaced the o2's
LS1Tech Premium Sponsor
We've seen them setup as high as .10x" from the factory, but we recommend closer to .040-.060" for the average combo around here.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
