Changing valve springs sucks..
Old 08-06-2009, 09:28 AM
Vcious04's Avatar
Default Changing valve springs sucks..
Forgot how much of a pain in the a$$ it is to change valve springs, esp with the twist handle tool with the 2 hooks.. Thats all..
Old 08-06-2009, 09:33 AM
Greg Pippin's Avatar
yeah it does suck.
i found the best thing to do is to get a friend with small hands to do the back two on each bank!!
Old 08-06-2009, 09:35 AM
Vcious04's Avatar
Originally Posted by Greg Pippin
yeah it does suck.
+1, freekin hands hurt from turning that damn handle! Esp makes me mad when it popps off about halfway through compressing the old spring.
Old 08-06-2009, 10:03 AM
massls1guy's Avatar
I'm going to use this one next time, supposed to be the best tool:
http://www.speedinc.com/cont.cfm?cid=C0000900
Old 08-06-2009, 10:28 AM
Aaron91RS's Avatar
that's what I use and the first thing I thought of before I opened this thread.
I'm thinking springs are so fricking easy on an Ls1. You don't even have to use rope or air in the cylinder making is SOOO fricking unbelivably easier.
You can do them in like 45mins.
Then I opened the thread and realized you're doing it wrong!
Old 08-06-2009, 10:44 AM
01ssreda4's Avatar
I used Tim's tool, it worked pretty good.
Old 08-06-2009, 10:45 AM
GT Griller's Avatar
We took the head off the tool and turned it with a ratchet.
Old 08-06-2009, 10:49 AM
Vcious04's Avatar
Oh well, it's too late now. Does look like a nice tool! I got it done in about an hour, but none the less, it still sucked..
Old 08-06-2009, 10:53 AM
crossroads's Avatar
I bought a "tims tool" and it broke in the head on me and lost two locks at the same time....the tool did work good till the seventh valve or so(i'm not raggin his tool BTW), but to finish the job i got the one Thunder Racing Sells, nice tool i finished in no time with minimal effort, but there office is not even an hour away so it worked out nice
Old 08-06-2009, 11:06 AM
EndlessSummer85's Avatar
I bought just a standard valve spring tool, you can buy them at sears, autozone, etc etc. Cut off the t-handle and put two nuts as a jam nut and used a gear wrench to turn it. It worked really well, just took a little bit of time doing one spring at a time.
Old 08-06-2009, 11:14 AM
bearcatt's Avatar
The tool in this link looks like the old Crane tool.
Has anyone used it on heavy dual springs ?
Old 08-06-2009, 11:47 AM
I used the one from sears, and broke 3 of them doing my springs.
After i got done i brought them back and got my money back for 2 of them and got 1 exchanged for a new one.
I think next time i will be buying the tool from Speedinc...
Old 08-06-2009, 12:03 PM
LSX Mechanic
Damian's Avatar
The Crane tool > Every other valve spring tool on the planet.
Also, use the TDC method for holding the valves up rather than trying to stick an air fitting in each cylinder. Much easier this way.
Put #1 at TDC, do cyl 1 and 6. Rotate 90*, do 8 and 5, rotate 90*, 7 and 4, rotate one more 90*, do 2 and 3. Done.
Old 08-06-2009, 12:58 PM
TS99V6's Avatar
Yes, I've changed out about 8 sets using my Crane tool. Takes no time at all.
Old 08-06-2009, 01:13 PM
bearcatt's Avatar
Thanks bud, that makes me feel better.
I'm looking to remove my dual springs for a set of PAC behives.
TDC method sounds good to me.
Old 08-06-2009, 02:47 PM
Brandon35thSS's Avatar
+100000000
the crane tool is awesome. i love doing 2 at a time!!
Old 08-06-2009, 02:56 PM
TooLateVTEC's Avatar
Is the Crane tool the same thing as the Speed Inc one or is it different?
Old 08-06-2009, 08:41 PM
01ssreda4's Avatar
I used Tims today for the first time on dual springs today, I have to say it worked great. I had previously only used it on beehives.
Old 08-06-2009, 09:46 PM
Chrome355z's Avatar
Crane tool here, I wouldn't use anything else...
Old 08-06-2009, 11:18 PM
LSX Mechanic
Damian's Avatar
Yes, they are reproducing the design.
The tool I have is actually the Speed Inc version of the Crane tool. I've owned the Crane tool in the past but I loaned it out and never saw it again. The Speed Inc tool is identical in quality and function.
