5.3 truck crank in a LS1 block???
Old 08-14-2009, 09:02 PM
rms25thta's Avatar
Default 5.3 truck crank in a LS1 block???
The crank I have is out of a 5.3 truck motor. Will this work fine in a LS1 block?
Old 08-15-2009, 06:26 AM
rms25thta's Avatar
Nobody???? I know someone has an answer to this one.
Old 08-15-2009, 06:39 AM
nastychevelle's Avatar
the crank out of a 5.3, a ls1 and a 6.0 are all the same
Old 08-15-2009, 07:37 AM
rms25thta's Avatar
I did do a search. What I did find out was that there were a few different style that had different dimensions for the rear seal but I didn't find enough to identify which was which. I appreciate you replying back because I have seen tons of your posts and you are one that seems like you know a great deal about these engines.
Old 08-15-2009, 09:27 PM
got-a-ls1's Avatar
I believe it was the 6.0 crank that had the different rear seal area (longer i think? not sure..) , possibly because of the 4l80e tranny it mated to?
Truck cranks are also not gun drilled like ls1 cranks which makes them heavier but not necessarily stronger. It should be fine but id wait for someone with a definite answer before i committed to buying anything.
Old 08-15-2009, 09:34 PM
5_02ls1's Avatar
the only difference is its about a pound heavier do to the gun drilling of the ls crank.....it will work just fine....
Old 08-15-2009, 10:22 PM
rms25thta's Avatar
thanks guys, I appreciate it.
