Oil cooler Q
I searched and haven't seen anybody with an oil cooler mounted up high like this:![](https://ls1tech.com/forums/picture.php?albumid=10912&pictureid=30612)
![](https://ls1tech.com/forums/picture.php?albumid=10912&pictureid=29908)
I haven't started it yet. Just curious if i'll run into any problems, maybe pcv? I'm hoping to fire it up tonight, I'll crank the motor over to fill everything with oil.
Thanks, Russ
Thanks, Russ
It should work. Kind of like the Off road trucks with their rad. in the bed. I would tape some string on the hood and see if the air is drawn in or pushed out of the hood. Why because a cowl hood draws the air in at the base of the windshield. t really doesn't matter as long as you have air flow across the cooler. I mounted my coolers in the nose cone. i removed the styrofoam off of the metal cross piece. Then mounted them on that , with a pusher fan.
Just got back from a spin up Provo canyon. It maintains 45 psi hot idle pressure and when i glanced down at the gauge it was 65-70 psi WOT @ 5k rpm. I'll wait to run it hard after a couple shake downs.
THE COOLER WORKS BEAUTIFULLY! I also installed a front splitter that directs more air into the radiator...I turned the rad fans off to see how hot it would get and the water refused to budge above 195 running up and down state st light to light. Oil Temp sender is installed, just need to run the wire to the gauge, then i'll be able to monitor the oil.
I'm happy, the car's been parked for a month and a half.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
My new ebay prize
Believe it or not, used XRP light weight lines off one of Richard Petty's nascars. They're ridiculously feather weight, I could've never afforded these @ $47 a foot new.
