power steering pully fit
Old 08-15-2009, 03:16 PM
kglow's Avatar
Default power steering pully fit
Determined my loud undriverable fan belt noise is because the PS pully is not pressed on far enough to the pump. I replaced this pully with a new GM one about a month ago. Have had the noise ever since.. I move the belt over two ridges to the inside and the noise is gone. Can someone tell me if the ps pump shaft should be flat with the outside of the pulley. I am trying to press it on more but I don't know how much pressure it takes to get it on. Seems awful tight right now, Any measurements would be great. 1998 LS1 Trans AM.
Old 08-15-2009, 03:47 PM
kglow's Avatar
I pulled the pulley and it appears to had been all the way on. Is there anyone who can check a GM part # for me. I am wondering if GM sold me the wrong pulley? Thanks. The number on my new pulley is #12559885
Old 08-15-2009, 04:16 PM
kglow's Avatar
Just reinstalled the pulley and the noise is gone. I guess gremblins were at fault. Thinking the pully was either not all the way on or crooked.
Old 08-15-2009, 10:13 PM
S10xGN's Avatar
No way to get it on crooked. The shaft will be recessed about 1/8" inside the pulley hub (at least it is on mine)...
Russ
Quick Reply: power steering pully fit
