Crankshaft Drilling Question.......
I am installing a 6.0 in my car and am transferring a Vortech blower setup to it. Question is.......what have you guys used in the past to drill the crank in order to put on your ATI balancers? There is a dow pin that goes all the way through the crank, and being it is a hardened piece of steel was wondering what you guys suggest?
Thanks
Thanks
Ati has a crank pin kit. I used it on my crank no problems. The stock crank shaft is cast so the drill bit they give you in the kit worked just fine.
http://www.exoticperformanceplus.com....html?item=458
