main bearings
Old 08-16-2009, 12:48 PM
King Nothing's Avatar
Default main bearings
to check the main bearings, can i pull the pan off the check or do i need to pull the block totally out? my reason of checking is i'm at 157,730 and my oil pressure has been low for 2 years now and i have everything for the heads cam swap including the ported oil pump but i'd still like to check the bearings to make sure. thanks
Old 08-16-2009, 01:06 PM
JPH
JPH's Avatar
Drop the k-member and pull the pan and check a few.
Old 08-16-2009, 11:20 PM
ok, i finally got to thinking if i could do this without pulling the engine out i can save ALOT of time. have you done this or who has done this so i can get some feedback of the experience. thanks
Old 08-17-2009, 05:02 PM
quick346's Avatar
I would be very carefull going that deep into the engine if you have not done it before.
at least get someone to help you that has done it before. One mistake and you will have nothing .
good luck
Old 08-17-2009, 06:51 PM
1Loudz28's Avatar
just try not to fail when you do this john.
Old 08-18-2009, 12:08 AM
you dick dan lol how are those headers workin out for you?
