L33 to Z06 Cam Swap
Old 08-19-2009, 02:33 PM
modracer33's Avatar
Default L33 to Z06 Cam Swap
Any reason why a 2001 LS2 Cam could not be used in a 2005 L33 "B" Code engine? I'm swaping the engine into a car and plan to go to the 2001 LS2 Z06 Cam.
Thanks!
Old 08-19-2009, 02:53 PM
eseibel67's Avatar
2001 Z06 cam would be called LS6, not LS2.
Besides that, I'm not sure if that cam would fit in the L33, but I think it will.
Someone will confirm this for you.
Old 08-19-2009, 03:37 PM
modracer33's Avatar
What I should have said was that the guy who sold it to me told me it came from a 2007 Trailblazer SS LS2 with Cam Specs of 204/211 .525 .525 116.5 LSA.
As I understand it this is the same as the 2001 Z06. My concern, now that I own it, is that it is out of a 2007 and I had read on another thread something about the cams LSx cam changing after 2005.
My L33 is a 2005 engine.
Thanks!
Old 08-19-2009, 05:47 PM
one fast zo6's Avatar
dose it have a dual ramp wheel on the back of the cam? if yes then it will work great.
Old 08-19-2009, 05:56 PM
transamfreak01's Avatar
not sure if it would work but my question is why? if you have another motor why not put a bigger cam in it? i think its a waste of time putting a stock cam in
Old 08-19-2009, 06:25 PM
modracer33's Avatar
"not sure if it would work but my question is why? if you have another motor why not put a bigger cam in it? i think its a waste of time putting a stock cam in"
I'm putting a L33 from a Chevy Silverado into a Miata. Don't need the torque of this cam. I need a cam that will run with corvettes..
and I only paid $80 for this cam..so not a real waste of money.
So I just need to know if this cam will work in my L33. Not sure what a Dual Ramp wheel is.
Old 08-19-2009, 06:52 PM
modracer33's Avatar
Well I think I found my answer in this thread:
https://ls1tech.com/forums/conversio...e-ls1-ecm.html
Appears I have a cam that I can possibly use assuming I can get the 1x timing gear and the LS2 timing cover. But I am not sure if I can get a 1x timing cover with a 1 the single bolt hole instead the three bolt pattern.
Any ideas?
Old 08-19-2009, 11:24 PM
5.3LJimmy's Avatar
I don't think they make a 1X timing gear for the single bolt cams.
Old 08-28-2009, 05:06 PM
sparkwirez06's Avatar
Does your L33 have a rear cam sensor? 3 bolt cam?
Old 08-28-2009, 10:18 PM
5_02ls1's Avatar
i thought the l33 was a gen 4 motor?????if so the cam should be a direct drop in....and im pretty sure the ls2 cam is similar to an early ls1 with .500 lift???????????????????????????????
Quick Reply: L33 to Z06 Cam Swap
