searched & no luck....knock sensor ?
Old 08-20-2009, 01:49 AM
klujan13's Avatar
Default searched & no luck....knock sensor ?
I am in the process of an LS6 intake swap and want to replace the knock sensors while I am there but all the sponsors only sell 99-02. Do I need to have a different knock sensor since my T/A is a 98 or can I use these?
Link--->http://www.ws6project.com/user_stor/...oducts_id=2065
Old 08-20-2009, 09:36 AM
bigboykilroy's Avatar
I have a 98 and have been here before. You want to buy the newer knock sensors if you have a 98 with the early rev knock plug then you can buy the newer updated knock harness that plugs into the newer knocks and the main harness i think when i replaced the 2 sensors and the harness it was like 90 bucks total.
Old 08-20-2009, 09:37 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
Should be 12589867 for the new knock sensor (x2) and 12601822 for the new knock sensor harness.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 08-20-2009, 03:44 PM
klujan13's Avatar
Matt, I was unable to find these on your website do you stock these parts?
Old 08-20-2009, 04:34 PM
Not on the website, but I can get them for you pretty quickly!
__________________
