LS6 ported oil pump vs SLP oil pump
Which one is better, more durable and performs best - LS6 ported oil pump Or SLP 'Heavy duty' oil pump Or is there one better out there? Thnx
Tsp ported and shimmed ls6 oil pump here, great oil pressure.
Cold start 60psi
Idle 48psi
Wot 80+psi
My bro has the slp and its 35psi @ idle. They say it depends on the spring you put in the pump.
Cold start 60psi
Idle 48psi
Wot 80+psi
mine is the same and i took my ls6 pump out and went for the slp only to have 40 psi wide open so i pulled the pump last night and took it apart whatever moron put it together left part of the casting flange in the bypass valve stuck under the seat, i wont by an SLP again
Raul
I wouldn't worry too much about pressure as long as it's at least 30's at hot idle. I ported the discharge side of my stock LS6 pump and reused the spring and it's low 30's at hot idle and high 40's I think at WOT (not real sure as I haven't checked it at WOT lately). I don't know about the SLP having 3 springs...doesn't make much sense to me as just 1 "long" spring fits in there. Also the pressure is completely dependant on the spring alone.
