How to install crank timing gear?
Old 09-22-2009, 11:06 AM
Bucktooth's Avatar
Default How to install crank timing gear?
How do you guys remove and install the timing gear on the crank? do you just pound it on till it bottoms out? What about removal.
I am installing an ls2 chain and was recommended to replace both gears as well.
Old 09-22-2009, 11:35 AM
voda1's Avatar
Did you try using the 3 jaw balancer remover tool? IIR just turn the old gear end for end to drive new one on.
Old 09-22-2009, 03:05 PM
vettenuts's Avatar
Removal and installation tools are about $30 total on flea bay.
Old 09-22-2009, 03:26 PM
TooLateVTEC's Avatar
What he said.
Or you could see if the local auto zone/advance has a set you could borrow.
Old 09-23-2009, 12:54 PM
01ssreda4's Avatar
Voda is right. Use a jaw type puller to get the old one off. Use the old one to drive the new one on. Hitting the old one with the hammer.
Old 09-23-2009, 01:11 PM
DANSBIRD's Avatar
BFH works every time.
Quick Reply: How to install crank timing gear?
