question about finding compression
Old 09-29-2009, 03:54 PM
LS1Adam84's Avatar
Default question about finding compression
Ok I recently installed 241 casting heads that were milled .042 I have a .051 mls head gasket on as well. I am just trying to figure out if what my compression ration would be with these heads.
If you know the formula that would be greatly appreciated, I welcome any and all responses.
Old 09-29-2009, 04:20 PM
500@10psi's Avatar
read thru the stickies lots of good info in there.
Old 09-30-2009, 01:56 PM
LS1Adam84's Avatar
Thanks yeah I don't know what I was thinking.. my brain has been deerrr mode after the whole thing i got it done in about 4 days all in my garage with hand tools and **** breaking left and right... mainly a rocker arm bolt and even the crank pulley (harmonic balancer) I broke one of the tabs off that you grab onto with the puller.
After spending about 4 hours going and picking up random parts here and there got head/cam headers y pipe and everything done. Not bad for a first timer and the car starts up and drives with some adjustment of the idle screw.
Old 09-30-2009, 02:21 PM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
On a stock LS1 short-block, you'll be at about 11.2-11.3:1 static compression (assuming pistons the average of .007" out of the hole and 60-61cc chambers). Hope that helps!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 09-30-2009, 02:39 PM
LS1Adam84's Avatar
Matt that does I used the .051 mls head gasket from you guys and from my understanding that decreased my CR by ~.1-.2, thats almost one whole compression point dang.
I want to throw a shout out, tsp comes through these guys rock I got all the parts to support a h/c install and they got everything to me quick, awesome company to deal with... Only thing is now I have to by more muffler lol, I have ebay headers going to a tsp ory (it was an easy install too they work perfect with ebay header) and the tsp rumbler and my car is now a 1/2 mile or more cop magnet.
