Lunati voodoo cam #60512
1 Post
You'll like it Running Lunati 55008 myself (advertised 243/252 .595/.595 112 lsa+4 (108)) but I mic'd it and it's really .600/.601 Got about 9K miles on mine so far and LOVE the pull from 3500+minus the nitrous and my 4.30 rears, near identical.
Does anyone know, what is piston to valve clearance with this cam?
My engine is stock LS3 (atleast at this point) only 1 3/4" longtube headers, open exhaust and fully programmable ecu. And is it suitable cam otherwise? My dealer suggested this
I dont mind if it doesn´t idle or pull under 2500rm, car is in plain track use.
Or other suggestion from Lunati or Compcams, these brands i can get in decent delivery time?
The only real way is to clay the piston and check it, but I would think it would clear just fine, with th right tuning almost any cam will idle and drive fine under 2500RPM....Lunati does have 3 more in between cam in the VooDoo line, you can find all 6 grinds on ebay, the Lunati site doesn't list the last and biggest VooDoo cam which is 237/243-600/600 113LSA
I would like to know if lunati makes anything of there own....ordered voo doo rockers and link bar roller lifters back in sept. of 2011, jan. 2012 called lunati and they said they were having trouble getting the lifters from MOREL and discontinued the roller rockers due to yella terra couldn't provide them just to sum things up...? is do they even make anything themselves now a days
Lunati was getting their rockers from Yella Terra? Well that just knocked them to the bottom of the garbage list for me, if true.
I'm gonna have to look into this a bit more.
