cam damage...big time.
well my motor let go a while back broke a valve spring, piston meet valve, cracked the cylinder wall/sleeve and then broke the rod.
well today I pulled the cam not expecting to see this...the lifters and push rods look 100% fine...I don't understand how this damaged occurred?
Chad
Chad
The same thing happend to me. Broken valve droping in cyclinder, hamming in between piston and block. Long story short, total lose. Look at the bright side, time to upgrade. Good luck with you're next built.
oh yeah I knew everything else was busted but to damage the cam I just didn't think how it would happen.
got a 6.0/4l80E waiting to go in...PRC LS3 heads and now a custom cam
Chad
