What heads to go with this cam: 226/224 110LSA
thats an awsome cam, i was thinking of doing the same cam , installed straight up, but i went agaist it....
I would go with a good porter/company that can work with you and has had good results, i would recommend Jay from absoulute, best for the money and has excellent results , and of coarse joe prince, but havent heard much from him recently!
Originally Posted by 93PONY
Yeah, it's one of mine. I'm actually doing the install today.
God I hate swapping valvesprings on these things....
dont they just suck! hehe nice cam specs, cant wait to see the numbers.
The longtubes & off-road Y need to be installed first however.
Originally Posted by jrp
whats the lift and can a smog tune be worked out?
This profile has 5 degrees of overlap at .050. A bit much to pass the CA sniffer.
What are you a smog tech? LOL
The bulk of the power of this cam is from 4K-6500rpm. It will make a little less power then stock under 2K rpm & more from there on up.
It was designed with stock heads in mind.
SN95 Director
lol, no , i just want a big cam that i dont gotta swap for emission.
Of course a cam swap is not real hard on these motors (once the valvetrain is already beefed up) & there are no gaskets to buy.....& if you buy a cam you'll have the stocker sitting there in a box. Just swap it out every 2 years!
Longtubes are much more of a hassle come smog time then a cam IMO.
SN95 Director
What you need here in Cali is a cam with negative overlap at .050. Until I get feedback on one of my 'smogable' cams that's been tested I stay safe at -4 to -3 degrees of overlap at .050. This makes the cams sound damn near stock, but they still perform quite well for their size.
