cam in a stock ls1
Old 10-12-2009, 08:28 PM
trxman's Avatar
Default cam in a stock ls1
I have a 2002 camaro ss m6 with 100,000. Is it possible to put this cam in without anything else:
http://www.texas-speed.com/shop/item...d=168&catid=44
Or should I just wait and get this head and cam package with the torquer v.2 cam and timing chain and oil pump:
http://www.texas-speed.com/shop/item...d=832&catid=47
Also will these heads and cam work well on a daily drivin 383 stocker ls1
thanks,
john
Old 10-13-2009, 06:08 PM
VincesSS's Avatar
You should definately do lifters, oil pump, timing chain, and of course valve springs with that mileage on a cam swap.
Old 10-13-2009, 06:27 PM
02*C5's Avatar
I will go one further with a 100K on the clock a compression test is in order IMO. I would do option number two it is better and safer, you'll save more money down the road.
Old 10-13-2009, 10:20 PM
trxman's Avatar
yeah Im just going to wait and put those heads and cam in a new block with tsp's 383 assy.
--john--
Old 10-14-2009, 07:55 PM
trxman's Avatar
i would love to do a compession check i changed the plugs about 3 months ago and theres no way my knuckles are coming off again. I should have just done it when the plugs were out.
--john--
