tfs 215 cam choice for auto 346
what are all you guys running? i was thinking of a 224/228 114+4 on an lsl lobe, or something similar. we have the stock bottom end, so we cant get wild with duration (p2v), nor do we want to. goal is a great daily driver that pulls all over.
You can actually run much bigger and maintain stock manners + big hp with those heads..
The 13'5* head gives more PTV so you can run a bigger cam safely..
Great low/mid lift #'s will keep good low end power and throttle response with an agressive cam...
I run a 230/234 111 LSA cam on ported OEM heads and have more everywhere.
You CAN have your cake and eat it too.
GM choked these motors cause they had to meet emmissions...Being A4 I had to get a stall...So get TFS or somebody else to spec you a cam....But go bigger.... Vengeance would be a place to start....
