ms4 cam one last?
Old 10-14-2009, 10:16 AM
SScamaro4's Avatar
Thumbs up ms4 cam one last?
when i put this cam in my ls1 all i need is to upgrade the pushrods and valve springs correct not lifters or anything someone tell me.
Old 10-14-2009, 10:21 AM
TooLateVTEC's Avatar
For one thing, "alls" is not a word.
Second, no thats not all you need. Your going to need a front cover gasket, water pump gaskets, oil pump o-ring.
If your car is an auto, youll need a stall. If its a M6, youll need a clutch really soon.
How many miles are on the car? If its less than 50k the lifters will probably be ok. If more than that, they're on borrowed time with a cam like that and the spring pressures that come along with it.
Good luck
Old 10-14-2009, 10:40 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
Like stated, there are other items to consider, the cam gasket kit being the minimum.
http://www.texas-speed.com/shop/item...id=85&catid=36
What other mods have you done to the vehicle? What kind of vehicle is it? Auto or 6 speed? What do you do with the vehicle (daily driver, all race, combo of both?)? Let us know some more info and we can help be sure you get what you need for your vehicle.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
