tr230/224 111lsa cam questions
Old 10-20-2009, 06:54 PM
ls1curt's Avatar
Default tr230/224 111lsa cam questions
hey, i found a good deal on a thunder racing tr230/224 111 lsa "reverse split" cam. how is the drivability with this cam? how is the idle sound? i want to get around 400 whp cam only and still be able to daily drive it.
thanks
Old 10-20-2009, 07:35 PM
thewholefnshow1's Avatar
I'm no expert by any means but I would say depending on the lift of the cam which I don't know but on a 111 LSA it should hit a good lick. But TSP has some good stuff and I would think it's driveable but I would say it's all in the tune. Just depends. You may can youtube the cam and see if you can find it. While your there you could see if you can find an UD pulley get that thing to rev faster.
Old 10-20-2009, 08:16 PM
ls1curt's Avatar
thanks yeah, i would def have to get a good tune, couldnt find much any good on youtube. the lift is .575/.563
Old 10-20-2009, 09:03 PM
outkast6991's Avatar
how much are you gonna pay? the cam will meet your goals for sure. as for the sound i can get you a clip in the morning if you want
Old 10-20-2009, 09:13 PM
ls1curt's Avatar
i found a used one local for $250, okay that would be sweet. i want a pretty lumpy idle
Old 10-20-2009, 09:15 PM
doylie24's Avatar
sound clip would be great, thinking bout this cam as well
Old 10-20-2009, 09:32 PM
thunderstruck507's Avatar
it has a nice lope to it, my copy idles as low as stock and is perfectly driveable but if you have an auto you will need a stall or it will push through the brakes and cause those kinda of issues
Old 10-21-2009, 08:14 AM
true duals with single chambers dumped
catted y with a loudmouth
cam is coming out in the next couple weeks and will be for sale
Old 10-21-2009, 06:35 PM
KING Z28 HAWK's Avatar
outkast is your true duals set up with a x or h pipe? Its sounds really good!
Old 10-21-2009, 06:42 PM
zacht's Avatar
theres a thread in the dyno results section with this cam, its on a red 00 TA, he hit 416/411. lift on that cam is .575/.563. iirc he was bolt on, stock heads.
its 150 bucks off the cam, not to mention the stuff you need to buy to go with the cam, matching springs and pushrods are a must.
i think itd be a good cam for the street and it makes good power.
Old 10-21-2009, 06:49 PM
supersick99z's Avatar
if im correct this is a considered a reverse split cam and reverse splits are known for making great power!
Old 10-21-2009, 07:45 PM
TXZ28LS1's Avatar
what are you talking about? reverse split cams suck!! they dont work..
Old 10-21-2009, 07:53 PM
lemons12's Avatar
From what I have gathered it is a bit harder than just "tossing in" a reverse split as a traditional everything doesn't have you be as exact for all the parts.
I do know for sure you have to have a VERY free flowing exhaust for a reverse split to shine. And if I am not incorrect, they are not known for their power.. They are known for their TQ, where and how much they make is insane.
Also IIRC they are better suited with stock intake/head setups than aftermarket.. I believe that is where traditional splits take over.
Correct me if I am wrong, have only done a little bit of research on them.
Old 10-21-2009, 07:57 PM
sorry i forgot lol
Old 10-21-2009, 08:04 PM
TXZ28LS1's Avatar
thats the thing man, alot of people on here are quick to diss reverse split cams. alot of people doubt these cams once you add heads and a fast intake, but there are people that still make power and not lose power which is what i would think. look at the latest guy with a TR230/224. he made 41x hp/ 41x torque.. stock heads i believe. i dont think i have ever seen a traditional split with the same size make close to the same amount of torque. heck, even predator Z el torro cam made crazy torque.
i posted a link for an old reverse split cam from MTI 230/227. it was maybe 6 years old.they put it in a 422ci motor.. it made 48x/ 508 torque..thats with LS6 heads and LS6 intake.. i could only imagine the power it would make with some AFR/TFS heads and a fast intake. that is pretty damn impressive for such a small cam that people think dont work..
Old 10-21-2009, 08:08 PM
its a custom x that tucks through my driveshaft loop
Old 10-21-2009, 08:12 PM
lemons12's Avatar
Got ya! I wasn't dissing it by any means.. They interest me greatly and I'm thinking of one for the GFs car when its time to cam hers as she will stick with ls6 intake and stock heads.. Just from what I have gathered (even from Pred Z) is that they arent as easy as just "tossing" one in.. If that makes sense. All the small things make a greater impact on the reverse splits than they do on traditional.. Biggest thing being the exhaust restrictions.
Old 10-21-2009, 08:37 PM
TXZ28LS1's Avatar
yeah man, i hear ya!! also look up a member named gillbot. he has mac midlength headers and TR230 and made 399rwhp!!! thats with a 4k stall too.
im looking into adding heads with my X1..
Old 10-21-2009, 08:40 PM
lemons12's Avatar
Sweet, I will look into it! Every time I research them I want one for her car more and more..
Old 10-21-2009, 09:16 PM
davith's Avatar
Not to hi-jack this thread but how does this cam compare in terms of perfomance on stock heads, LS6 intake to a TSP228R?
Quick Reply: tr230/224 111lsa cam questions
